First few days was fine but now my screen shakes and jitters and makes Elite Dangerous completely unplayable. What is going on?
Hi, did this issue occur in Elite Dangerous only? Have you tried to manually install graphics driver or adjusted “Render” in Piplay setting?
Please use Debug_tool in Piplay setting to export logs to support@pimaxvr.com
Forgot to mention, When I start my pimax now it is not centered properly and the pressing recenter is off center as well, way too much to the left. I have to move my head right and press recenter to force manual center. The drift gets really bad… this is on steamvr. will try redoing room scale setup
Room scale setup fixed positioning. Will test for screen shake soon.
Shake has been significantly reduced since I’ve redone room scale in SteamVR.
Thank you for your efforts, quick response and awesome support so far. Very impressed with you guys.
-Matt
