Solid 90fps. 1920x108. Make sure fluid sync is set to off. Enjoy!
There is a profile in the vorpx cloud profiles called “high fov” for the pimax. It looks perfect. Give it a shot it’s really good. (And has fluid sync off) just follow instructions in the profile description.
I agree rocket league in vorpx a blast. Especially on the 5k+
I’m running 2560x1440 and still getting 90 with 5k+ and 1080ti. Max gfx but motion blur off and lens flare off. I also have steady cam settings on in the options, and fast ball cam snap.
Oh awesome! Will check it out
