[Resolved]So i have no led light and my Pimax is not found what so ever
as i stated my HMD does litterly nothing… PLS help or is my unit doa? i cannot flash any firmware because it wont start at all…
@PIMAX-Support
http://community.openmr.ai/t/my-pimax-just-died-after-piplay-update-resolved-t-y-sjefdeklerk/1960/11?u=sjefdeklerk
nope no lights at all. it was never active since i have it.
ah ok that sounds like a DOA then indeed
just to be sure the HMD should show any sign of life when plugged into an USB port? like anything LED related?
even if no software is installed?
Yes, the LED should light up. Also the manual DFU mode should work (described in the link I posted), if that doesn’t even work then the unit is dead (although I’d try it on another pc to confirm)
so !!!
i would like to make an statement here!!
  1. first of all that PIMAX does bild it stuff in an awsome manner if i where from IFIXIT i would give this device an 10/10!!!
  2. the white ribbon cable from the power button fell off… so i get my ifixit kit and watched that manual on youtube… and fixed the cable situation !!
@ Pimax your device design is easy and understandable! 10/10 would recomend!
:smiley: iam happy and thx fpr the fast replays°!!!
Awesome Domrock1! Glad you were able to fix it up. I am sure support will like your endorsement. :v::sunglasses::+1::sparkles:
