[Resolved]OVR_Laucher crash
I cannot get the Pimax to run anything in pimax mode, how can I fix this ?
@PIMAX-Support
This is the error OVR_launcher gives me:
Unhandled exception at 0x00007FF9CD0E2208 (ucrtbase.dll) in OVR_Launcher_x64.exe: An invalid parameter was passed to a function that considers invalid parameters fatal.
When I look in the logs;
INFO: database is closed!!!
Aug 20, 2017 10:19:26 AM com.pi.piextend.aa a
INFO: logoPath:http://cdn.akamai.steamstatic.com/steam/apps/236390/header.jpg
INFO: logoPath:http://cdn.akamai.steamstatic.com/steam/apps/613220/header.jpg
INFO: DATA_UPDATE_READY:
INFO: state : DATA_UPDATE_READY
Aug 20, 2017 10:19:29 AM com.pi.piextend.aa a
INFO: Reachable local IP is found, it is 192.168.0.181
Aug 20, 2017 10:19:31 AM com.pi.piextend.aa a
INFO: newVersion:1.2.97
INFO: url:http://139.196.243.25/pi_us/piplay/version/1.2.97/PiSetup_1.2.97_en.exe
INFO: size:649957825
java.sql.SQLException: Unable to create correct SQLException class instance, error class/codes may be incorrect. Reason:
** BEGIN NESTED EXCEPTION **
MESSAGE: Can’t instantiate required class
STACKTRACE:
java.sql.SQLException: Can’t instantiate required class
at com.mysql.jdbc.aO.a(Unknown Source)
at com.mysql.jdbc.bc.a(Unknown Source)
at com.mysql.jdbc.as.b(Unknown Source)
at com.mysql.jdbc.o.c(Unknown Source)
at com.mysql.jdbc.o.(Unknown Source)
at com.mysql.jdbc.Z.(Unknown Source)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at com.mysql.jdbc.o.a(Unknown Source)
at com.mysql.jdbc.NonRegisteringDriver.connect(Unknown Source)
at java.sql.DriverManager.getConnection(Unknown Source)
at com.pi.c.f.b(Unknown Source)
at com.pi.pimanager.i.b(Unknown Source)
at com.pi.pimanager.i.aB(Unknown Source)
at com.pi.pimanager.o.d(Unknown Source)
at com.pi.pimanager.o$c.run(Unknown Source)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.runAndReset(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.ClassNotFoundException: com.mysql.jdbc.exceptions.jdbc4.MySQLNonTransientConnectionException
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
… 28 more
** END NESTED EXCEPTION **
at com.mysql.jdbc.o.<init>(Unknown Source)
at com.mysql.jdbc.Z.<init>(Unknown Source)
Aug 20, 2017 10:19:32 AM com.pi.piextend.aa a
Aug 20, 2017 10:19:35 AM com.pi.piextend.aa a
INFO: Task get Connnection From Service!
Aug 20, 2017 10:19:36 AM com.pi.piextend.aa a
INFO: onDeviceMonitor ID: 6
INFO: DEVICE_PIMAX_VERSION : -16
INFO: bright : 0
INFO: SerialInfo : 10071172101100-1DF LcdInfo : -1 FirmInfo : 1.0.0.265pordCat: 00
INFO: SerialInfo : 10071172101100-1DF FirmInfo : 1.0.0.265
INFO: onDeviceMonitor ID: 17
INFO: mode : 64
INFO: modeS : 224
INFO: intemCnt = 2
INFO: onDeviceMonitor ID: 16
INFO: connected
INFO: DEVICE_PIMAX_CONNECTION : 2
INFO: onDeviceMonitor ID: 19
18 f6 00 00 Aug 20, 2017 10:19:36 AM com.pi.piextend.aa a
INFO: pVal : 63000
@tivl82 Hi, may I ask some questions as below?
  • What’s Piplay version you use at present? Have you installed Piplay driver after disabled anti-virus software?
  • Have you both plugged the HDMI cable of the helmet and the cable of monitor to PC discrete graphics ports?
  • Did Piplay detect the helmet in Pimax mode? If not, what’s the color of indicator light on the helmet?
Please use Debug_tool to export logs to support@pimaxvr.com, we will analyze it and find out a solution, thanks in advance. :slight_smile:
Hi,
I’ll send the log later the main problem is that the pimax shows the “pimax” logo but only video mode works for me. The apps in piplay hang my system.
  • disabled antivirus
  • tried displayport instead of HDMI
  • switched laptops
  • disabled windows defender
  • Installed latest piplay
  • Installed latest java version (first manual, first JRE then JDK, then reinstalled piplay. Then uninstalled java and reinstalled piplay to allow piplay to install the java it wants)
  • Installed latest Nvidia drivers, with “force clean install”
  • set Nvidia to “performance mode” and tried all settings possible (ultimately, in the logs it shows the Nvidia is detected while I still get the popup telling me I should check my settings or wether I have Nvidia)
  • fixed service issues (“interactive mode” wasn’t enabled and showed up in eventlog as error, had to change ownership for some services around COM+)
Is there a way to manually debug everything ? I’m a developer, but I cannot seem to find a way to debug this problem. The pimax works in video mode, works well as an extended screen/desktop but in pimax mode I get the pimax logo and nothing will go to the glasses. Are there debugging or testing methods to trace every step ?
Thanks,
Tim
This issue is related to http://community.openmr.ai/t/resolved-cant-get-into-steamvr-on-laptop-please-help/2704/14
