I mean that when it’s booted up the led on top shines green. It does not blink or anything. From what I’ve found this is the correct behavior.
I’ve unfortunately tried all of the steps in that wiki related to tracking issues already. Will try to flash the firmware tomorrow if nothing else pops up.
EDIT: Apparently I have reached my maximum number of posts for today, so I have to wait another 19h to post again (great feature!). So I will reply below instead.
Ah, I misunderstood you. I guess it’s not in DFU mode then.
There is no config folder there for me. Only 25 log files and a profile.json.
@cruser_icu I own 2 lighthouses but one of them came without a power cable. So until I receive my replacement in a couple of days I only have one lighthouse.
You are currently a “basic” user(Trust Level 1). I am assuming the post limitation is intended for spam prevention (since it is fairly easy to become a “basic” user).
You will be upgraded to a “member” user (Trust Level 2) once you meet the following criteria.
Sorry about the late reply. Been blocked from posting in my own thread as my forum account is new. I’ll reply in order.
There is no config folder there for me. Only 25 log files and a profile.json. I checked for hidden files as well but none to be found.
The only weird thing in the diagnostic is Steam VR. I have reinstalled it twice and it keeps saying so. But my issue appears already in PiTool, so not sure if it could be related.
Firmware V2.1.255.181
PiTool version *.95, but previously tried with *.91 as well with the same result.
Tried it a couple of dozen times in various ways but no luck. The state of the lighthouse in PiTool changes from “Ready” to “Not tracked” when it’s obscured, but that’s all. It takes a little while for it to go back to “Ready” state though.
Yes. It’s just a very weird solution and worse, one that punishes their paying customers. I don’t understand how preventing users from replying to their own thread is a risk. As this is the official forum, they could at least let us buyers verify that we are in fact paying customers rather than hindering us from fixing problems with their product. Having a minimum wait period of over two weeks to be able to post properly is not exactly ideal.
Tried ending the other three processed related to Pimax. All that happened was that the lenses went black, the led was red and then it booted up again to its previous behavior.
It isn’t a very strict requirement (from a forum point of view) but in this sort of situation you could just request the forum moderator (@Heliosurge) to raise your level.
Being restricted to 10 forum posts per 24h for 15 days is very strict for an official product forum. A 1h wait I’d be okay with. 24h is just absurd. Anyway, this is off-topic. I’ll try to speak to Heliosurge, thanks.
I have tried it in all three modes, and I have tried both of my lighthouses (but one at a time), each located at opposite corners of the room (currently using the one which is ~1,5m from my seated position).
I am not able to run room setup because the tools notice that the headset is not tracked, so it doesn’t allow me to click “next”.
Very possible. Not accessed these before. I assume it’s the one in Event Viewer under the “Security” choice? Anything in particular I should be looking for?
