Which controller is better? Trackpad or the thumbstick? Hybrid?
I prefer thumbstick… i can play all games with that?
If I order it (headset+controllers), I get only the headset yet? Because it seems the controller are not exist now. How long do I have to wait? because I think first the backer / pre-orderer will get it. That would take months?
(sry for my english… wenn du deutsch kannst wäre mir eine Antwort in deutsch lieber :))
Controllers & LHes are coming out later. Pre Order is a deposit as price is not finalised. Aa for Thumbsticks vs trackpad? Hard to say which is better. If your interested in trying a mix I would reccommend buying a Steamcontroller. Trackpad can have benefits but like anything new takes time to learn & adapt.
Myself? I think one of each is good. Myself as a backer of 2 headsets opted for a complete set of both controllers.
You’d should receive headset first & LHes & controllers when available. Probably End of q2 or early q3 (only a guess) @anon74848233 & @Matthew.Xu may have a better idea. Though likely only an estimate.
The headset can still be enjoyed with 3dof with Seated games.
Thank you for your answer :).
A deposit… that means if the final price is higher, then I have to pay the rest later?
(or lower, than I got the money back?)
Probably End of q2 or early q3…I have only a mixed reality headset and I can’t use this controllers.
Too bad, I think I wait until everything is available for purchase.
I think maybe the base station will be earlier than the controller.
However, I don’t have time to collect more information about base stations and controllers.
Perhaps there will be new news on CES. Thank you.
Thanks for the answers
Ok, i see… but then I have to wait additional months, because as I said before the pre-orderer will be supplied…
But I can buy the sensor+controllers from other systems? For example Oculus Touch (without the oculus headset)?
All games works fine with that and the pimax headset?
If I understand it right, if I order the pimax 5k headset today, they will send my order 21st Feb?
Do backer can use coupon to buy at the backer price or retail price?
I am interested in the base station & controller set, but not sure when we can buy. Do we need to buy from store and use coupon?
Edit : Remember that xunshu ever tell that can’t use coupon with base station because it come from the partner.
