Recenter Headset with shortcut
Hello,
for now i m using a old Piplay the 1.1.92
So i want a shortcut to recenter automaticly my headset, because ingame, the headset move to fastly.
and with piplay 1.2.53 u can remove the headset clic on recenter on piplay and take the headset, it’s too long.
so i want a shortcut to recenter automaticly the headset ? like F12
how do that please ?
after that, i know a tools (naming VOCAL), u can talk to the computer to recenter automaticly the headset.
There is no shortcut function currently presented, so you have to use in-game options for recenter (most of games has it)
Could it be possible to have the headset center using custom assigned key strokes in the next PiPlay build instead? Then it should not interfere with any existing commands in game and it will allow the unity to be centered while in SteamVR before entering a game or any other time when using VR Desktop type applications as many desktop apps like Bigscreen VR only allows you to center the display using the application interface…
Would the devs consider binding a key to the piplay re-enter so we could try to use something like voice attack for a verbal command? I use it when playing elite dangerous but the re-enter binding is in game. But you can setup a profile for pretty much anything. As long as the app or game has a key binding which can be bound to piplay you could have it running behind the game and verbal command to reset?
I know there is a free to use voice attack that allows about 20 verbal command to be custom added?
Eno
@all, appreciate your good suggestion, I discussed with our engineers who are considering this to our further version, please be advised.
There is a steamvr shortcuts : http://community.openmr.ai/t/no-further-room-setup-is-required-to-align-the-center-lets-use-shortcuts/785
Some changes have been made due to the update, but the recenter is still the ‘z’ key.
