Hi there,
Pledged the 5K+ and the 8K,
but in the survey, if i mark both, it say`s: This question requires an answer!
HELP!!!
Hi there,
HELP!!!
Maybe they sent you an email for each headset you backed .
If so…wtf?
The Survey do not marked if its for the 5k+ or the 8K!
Yes you should probably contact support .
Aren`t we here in the “Support” section?
Send support desk your backer info & choice.
You are in the community support area, not official pimax support. Use @Heliosurge link above to ask them about it.
Eno
Hi all gents!
Whats this type of survey?
I got one asking for my adress and choice but not like this with ticles.
Saludos
Tino
The link goes nowhere!
Ok, thank you all!
Got an email from Pimax and do the survey over it!
Again, thank you all. <3
