Why is there no proper uninstaller for the PiPlay package? It installs a great number of files and packages. Yet none of them come with Uninstallers?
I am having an instability with some other software on my system. I chose to uninstall PiPlay via the control panel, but this did NOT uninstall the whole package. Now my USB keyboard will not restore connection if I switch away via my KVM and then back.
With the complexity of the packages that are installed with/by PiPlay, there should be a full UnInstaller. If I need to remove ALL files PiPlay installed, this is currently impossible.
Has there been any movement on this? As the prior install would screw up several of my other OpenGL based software, I had to completely wipe the drive and reinstall completely to get functionality back.
Does the Pimax software installer now have an uninstaller that removes ALL the changes/files?
And I’m still wondering just what it installed that completely destroyed OpenGL in DAZ Studio…
