I used to have an OCULUS RIFT before switching to Pimax.
I like to run LONE ECHO which I installed on my PC and is visible in my PiTool.
It would not start since the OCULUS engine would not run. I tried reinstalling the OCULUS SETUP but it will always fail and ask to restart my PC. I did not find any logs so far.
Did anyone encounter same problems and could help me out?
You could try uninstalling Lone Echo. Delete Pitool short cut. Reinstall LE. Pitool should re–import. This worked for me with In Death when it stopped launching from Pitool so might work.
Test launched and played a little LE today (no Revive) so it still works.
I was prompted to update to new software that is replacing Home at year end but selected not to do it at the time. Forgot the nameof the software, but it is the new Login software they settled on instead of having to open a FE (Meta) account.
I expect the prompt to occur again Jan 1
Also don’t know is it will install if you don’t have a Meta hmd.
