Hello, i have a problem with gates of nowhere and blade and sorcery with my pimax 5k+, when a take something in hand after i cannot left it. nothing happen when i puch grip button. Some have this same problems ?
Congrats on receiving your 5k+. What day did you receive?
@EarlyBackers will flag members whom have received headsets. I don’t have LHes & controllers.
@anon74848233 can you add to early backers group plz.
wednesday and tracking day after
very good surprise !
And i like it very much !
Yes a lot have this problem and i really hope it gets fixed.
What the verdict on this issue? Is it being looked at?
Can this be moved off the general discussion? This is a technical problem and should be put in the support section.
Done Toba you have received headset? Which one & Date plz.
Oh no i wish i had it now . I saw 4-5 people with the complaint. So far no one is able to play blade and sorcery with the pimax unless im proven wrong.
Do you guys have blade and sorcery? was wondering if everyone has this problem.
@Heliosurge @anon74848233 Anyone know how to get headset working with Ark:Survival Evolved? No matter what I do every time I start game it hard crashes headset (It powers off headset and will not let me turn it back on for about a minute. Small fov, normal, large and every setting doesn’t seem to matter it just crashes the headset.
Not sure. Do you still need revive? Will try to give it a run.
Try pitool at 0.75 in small fov.
@EarlyBackers Ark & pimax?
Has the VR support in Ark actually improved? Last I heard the support was horrible and not worth the effort anyway.
What backer number? 20 characters
i never use revive so I am not sure but no ark has native vr support. I never tried it though as I didn’t like the rift all that much
i am backer 4536, 20 characters too ^^
OMG I’m 4531 (20)
Some games have native VR support. However games like Drift are Oculus supported & need revive to work on steam compatible headsets.
Ie Dying Light.
@Heliosurge Thank you I just tried revive and ark does not even show up on list though I still tried to start ark after installing and still no dice. However I do have another question. How do you get around the errors in some oculus games like Robinson: the journey, I no longer have oculus plugged in and when i try to start game it says I have hardware issue and it can not start. Do i really have to have oculus fully setup just to use some of the games. Others work no issue. I appreciate your help trying to get ark to work If you think of anything else please let me know.
Tbh. I don’t have a ton of experience with revive. Some games get detected. Others need Revive to be injected.
@EarlyBackers may have better insight.
Some old games used to check for oculus camera.
