I still can not operate the virtual glasses pimax, I would like to know if there is a program that I am missing, I do not know what to do, install several versions of pimax, install several versions of drivers
I have windows 10 gtx 1070, i7 4790, 8gb ram.
Before I made them work, format the pc and they did not work anymore
When I connect everything appears in extended mode, but the problem is that I do not take the pimax program. It appears to me that he is disconnected, but I do not know what to do anymore. plug, unplug, install drivers, change windows. but the problem continues, try on another pc and I had the same problem.
and I can not install another firmware because it does not take my pc.
[17-12-26 18:25:51][PSRV] pi_server 64 Release
[17-12-26 18:25:51][PSRV] build time:Oct 27 2017 10:36:28
[17-12-26 18:25:51][PSRV] build version:36
[17-12-26 18:25:51][PSRV] old hmd config file not support.
[17-12-26 18:25:51][PSRV] load profile file:C:\Users\Dani\AppData\Local\Pimax\runtime/profile.json failed, use default value.
[17-12-26 18:25:51][PSRV] main tid:5984
[17-12-26 18:25:51][PSRV] event tid:5644
[17-12-26 18:25:51][PSRV] cmgr tid:12668
[17-12-26 18:25:51][PSRV] failed to load amdlvr32.dll or amdlvr64.dll
[17-12-26 18:25:51][PSRV] system adapters:
[17-12-26 18:25:51][PSRV] adapter 0 :NVIDIA GeForce GTX 1070(0-29704)
[17-12-26 18:25:51][PSRV] adapter 1 :Microsoft Basic Render Driver(0-32228)
[17-12-26 18:25:51][PSRV] redmgr tid:12152
[17-12-26 18:25:51][PSRV] start run render.
[17-12-26 18:25:51][PSRV] hpmgr tid:9644
[17-12-26 18:25:51][PSRV] extend display:, use main adapter
[17-12-26 18:25:51][PSRV] drmgr tid:9020
[17-12-26 18:25:51][PSRV] init internal drivers
[17-12-26 18:25:51][PSRV] init external drivers
[17-12-26 18:25:51][PSRV] rpc tid:9932
[17-12-26 18:25:51][PSRV] start idle client.
[17-12-26 18:25:51][PSRV] client 0(0) connected.
Do you have onboard graphics? If you do you need to disable it in your Bios.
There us an odd line in your log file where it says it tried to load amd. As you have Intel & Nvidia that looks off.
I have added pokes to your message to help support find your topic
Hi ,Could you please download Teamviewer13?We would like to assist you remotely by Teamviewer software.
Please contact us via the mailbox: support@pimaxvr.com
