Please no gross foam face pad!
Just watched the Tested video review… it looks like the face pad for the Pimax 8k is made of FOAM (like the Rift/Vive).
PLEASE consider upgrading the material to something that doesn’t absorb sweat/oil like a sponge! We need something that is easy to clean/wipe down!
I’ve got the Vive, and I am not a fan of what it uses. The Pimax 4K is far more comfortable, as far a I am concerned.
Thanks for your support. As for the face pad the standard is also same as Rift and Vive,using FOAM, but as you know 8K is modular design, so it is very easy to change the face pad and we also provide the high quality pad, such as leather pad.
You provide a leather pad? How would one go about ordering one? It is a MUST if you plan on sharing/demoing the headset to others!
How to order is still in discussion, but should be at least can order from Pimax official website
cool! and just to confirm, the default foam pad is completely removable (ie it is NOT glued on)?
yes, completely removable.
