Please add an adjustable toggle for ipd IN THE HEADSET for the 8k
I don’t know about the HTC vive, but the oculus rift has an adjustable toggle for fixing lens spacing in the headset itself. Using the software to try and fix lens spacing on my 4k is not working very well (will try and mess with it again later). The view still comes off as wrong, and this would be a lot easier with a physical toggle on the actual headset.
you are right, the toggle is already included in 8K.
Thanks for the heads up, I’ll definitely get the 8K in that case, this was my only problem with the headset.
Any chance that the volume buttons on the 4k could be used to change software ipd? I think a lot of people would prefer that.
