Pitool UI problem: transparency, invisible text
Hi all!
Pitool 1.0.1.132 (installed from the PiToolSetup_1.0.1.132_212.exe, the installer was downloaded from https://pimaxvr.com/pages/pitool, however the site states that the latest version is v1.0.0.132)
NVIDIA Driver: 430.86
OS: Windows 10 Professional 64-bit (Build 17134)
For some time my Pitool began to look like this (white rectangle in the middle is a popup):
Tried to reinstall - it looks the same. The problem appeared about 2 weeks ago after the regular update and remains to this day.
Is this a known problem? Is there any workaround?
Goto Nvidia Control Panel. Fxxa option.
https://community.openmr.ai/t/about-the-way-to-fix-pitool-interface-transparency-issue/16179?u=heliosurge
Thank you very much!
Your welcome. Which headset did you receive?
I’ve got Pimax 8K recently.
