JPiper
I have the 8K Pimax unit.
-Pros and cons.
Pros: It is a great VR Headset. I have not had any problems while using the Headset. I saw where a large number of Kick Starter supporters opted to receive the 5K version and I considered changing to the 5K but changed my mind.
I am glad I decided to keep the original 8K version. I am very pleased with image clarity. There is a slight screen door effect. However, it is hardly noticeable. The FOV is awesome even though I usually use the normal setting and have used the large setting a few times, it is adequate for me with the FOV in normal mode.
Cons: The sweet spot for the pupils is difficult to target. I would prefer each eye could be independently adjusted since my eye IPD is slightly different for each eye. For example, left eye 33.5 and right eye 32.5 and I also had an issue with the headset hurting my nose. I was able to resolve the issue by placing a small piece of thicker foam in the nose piece area.
-How the FOV immersion you into the game.
I do not play many games but the FOV seems to be fine in the games I do play. My primary use is in X Plane 11 since I have my pilot license. The FOV in X Plane is awesome. The original FOV in X Plane was about a third of what the 8K headset can provide for an immersive interaction in the flight in the simulator and gives you that real world feeling.
How does the resolution make you read text clear?
The text resolution is fine and I am now able to read the text and numbers in the cockpit of the plane.
Apparel/Design
It looks 21st century to me and is rather light for its size.
Wearing Experience
I have seen some people posting comments about the wearing experience for soft straps. I am not able to comment on the difference between hard strap and soft straps. I do not have a problem with soft straps. It is comfortable for me with the soft straps. The only issue I had was with the nose piece hurting my nose and uI used a thicker piece of foam to help eliminate that problem. It appears that the bottom of the lenses were resting on my nose.
Image Quality
Yes, I can see the pixels sometimes while X Plane is loading. However, after it loads it simply disappears when I am interacting in the flight simulator.
Performance (Your gaming experience with Pimax, you can share not only one game experience)
I currently interact specifically with X Plane 11 and the performance has been great. I know that I am limited by the performance of my computer hardware. I am also limited in performance by X Planes software as it relies heavily on single thread performance on the CPU while the developers work to convert to Vulcan and Metal to enhance multithread utilization. My current FPS in X Plane 11 average 25 FPS with PFC plugin for hardware interface.
PITOOL settings: HMD 1.75 FOV Normal 80HZ
Steam Manual Override Graphics all applications 32%
Application setting Graphics X Plane 100%
My computer:
7800X CPU
1080TI Asus ROG Graphics Card
32 GB Ram
SSD Hard Drives
Concluding Thoughts
I am happy with the headset but wish I had the light houses and controllers to go with it. I hope they will be coming soon!!
If I had the controllers, I would have more of a reason to interact with other games. On another note, the IPD adjustments for each individual eye would be a great improvement. One eye is always slightly clearer than the other because of the difference in IPD between the left and right eye. In addition, a wireless interface would be awesome.
