Pimax not being detected and labeled as oculus DK2
Installed pimax and it worked as soon as i turned it on ,connected it, everything was good. Played elite dangerous for a while. I then installed the oculus software (Did not disconnect pimax) and it detected the pimax and overwrote something in the headset so that it now is being detected as a DK2. Please help. :disappointed_relieved:
There is an issue with Oculus home i believe in another forum post. You will need to uninstall oculus software & reboot. Then reinstall PiPlay. Then reboot and try piplay.
I may have missed or expanded a step.
Is it good with pimax? (elite dangerous)
Are you using steam ‘supersampling’ in steam config?
I plan to try it soon too!
Not bad actually, the ghosting goes away (mostly) because space is mostly black. However; you will need a serious GPU my watercooled gtx 970 ftw was HOT after an hour and it could barely hold 60fps.
TLDR-yes its good
I didnt touch any settings in steam so whatever the supersampleing default setting was.
Format HDDs and reinstalled windows…
Im impatient.
Fixed it
Well, im playing on 1080 so i expect to improve picture quality by supersampling.
By the way, whats an supersampling on steamvr config (graphic comparnes on Elite you can watch here. So if you manage to get a new card this will be interesting for you =)
just not sure how good it works with pimax because i dont own the game yet
