Pimax 4k keeps connecting and disconnecting. This started happening after I upgraded to the latest software. I tried uninstalling, removing Java and the folders - reinstalled and still having the issue. I’ve also tried different USB ports.
I tested this on a different pc and it worked so know it’s not the headset.
My pc specs are i7 4790k, onboard graphics disabled, gtx 1080ti, 16gb Ram, Windows 10 Pro.
'Having the same issue. Mostly in flightsims . Randomly disconnects every 15-30 mins then reconnects but without any audio. Kind of ruins the fun… 6gb 1060gtx
Hi @Eueyj, have you closed any antivirus software when installing the Piplay? Did the Pimax 4K work well before updating to the latest Piplay? We are willing to help you with remote control. Please send the ID&password of Teamviewer13 to support@pimaxvr.com, Thank you.
