Hello, sorry but I still can not walk the pimax
Format, install windows 10, windows 7. Deleting the klite
I follow all the steps of the installation, connect and disconnect the USB ports, HDMI.
install versions 1.9. 2.0.5
I do not know what to do to make it work. some tip?
https://youtu.be/_6-9Sm40Hu0
Try this:
Search for and open Device Manager.
Select “View” & choose to Show hidden devices.
Scroll down to Monitors section and right-click/uninstall all inactive monitors listed.
Hi, have you both plugged the the HDMI cable of the headset and the cable of PC monitor to the ports of Discrete graphics? Have you used any converter/adapter to connect the headset?
You’d better disable the anti-virus software when you installed Piplay.
Anyway, please send ID&Password of Teamviewer software to support@pimaxvr.com, I would like to assist you remotely. And I will be available after 13 hours.
