So I can already say that the 2080Ti is too slow for the 8KX.
only a scale of 0.419999 … is reached in steamvrconfig.
That is far too little.
I hope it gets better with the 3090.
the picture looks bad with a bad graphics card.
so i recommend a fast graphics card. a 3090 or faster.
with a 1080ti you don’t need to try it. it looks like s.h.i.t.
even a 2080ti is much too slow.
there are games that go well and there are games that go bad.
it is also often a matter of attitude of SteamVR and Pitool. both play a really important role.
steamVR drastically reduces the resolution if the graphics card is too slow. you have to know that.
The Vive Delux Audio headband does not fit.
the plug is different.
the sound is not stereo with the Vive headband. it could be that you damage the audio input if you try anyway.
