Keep in mind you could also use the vr frames to protect lenses. As an added bonus if they are fitted with polarized lenses can add extra blue light protection.
You right. I’m probably will be using the frames anyway. One thing I’m not sure they won’t be in a way of eye tracking.
The aGlass eye tracking modules will likely allow you to install lenses in them, to be used INSTEAD of the VR frames.
what vr frames…? (2o charactrers lol)
The VR frames that folks can use to have fitted with prescriptions instead of using their glasses.
First stretch goal i beleive.
