Pimax 5k disconnected:diagnose 10500 after instalation of PiPlay
before worked without issues with PiTool
Tried couple times : plug off/on usb and dispaly port , restarting PC , servcies , nothing helps
It works before PiPlay installtion.
Have you tried open up your task manager and under services tab, PiServiceLauncher
right click on this and choose restart. This works for me on 10500 when I turn on and off 5k+ and gone wonky.
Whats PiPlay for? I am able to run everything without that installed.
As I understand it, they work similarly, but PiPlay / PiTool has lower overhead, so you should have a somewhat better framerate, if you do NOT use Revive.
