Does PC monitor affects pimax 4K resolution ?
My PC monitor has resolution 1920x1080 and in piplay also the 1920x1080 resolution is checked does this mean that pimax 4K resolution is reduced ? Can I change this ?
As i know it doesnt, maybe it could affect the perfomance a little bit, but wont reduce it directly.
Input signal is always 1080p or 1440p. It’s never been 4k. The only way people have been able to approach 4k resolution image quality is through super-sampling in steam or nvidia dsr which is a hardware based super sampling technique I believe. Both options require top end video cards to pull off a reasonable frame rate.
