Pimax 4k headset middle blurr
Can anyone from pimax hlep me with a issue with headset middle blurr please . Just bought headset and it has middle blurr please help.
Have you set the IPD to your correct setting? You need to measure the distance between you pupils… Easiest way is to use a ruler and a mirror.
Close eye and put ruler upto open eye on 0cm then holding still open other eye and look at the measurement… Set this in piplay settings.
Eno
Yes ive done everything possible i even had to put my girlfriend glasses on to see it come clear .i also have vive and oclus rift .i have read in some forums that the lens could b faulty.
Hi, please email me: support@pimaxvr.com about the order info as below, thanks.
Purchasing platform:
Order number:
Serial number:
Full name:
Address:
Postal code:
Telephone:
Same here ,
i just sent a mail to support
Hi. I am going through the same issue. What have pimax said to you about resolving it.
