Patented low persistence customized 4K panel inside Pimax VR
@all guys.
As you know, a patented low persistence customized 4K panel inside Pimax VR , it’s definitely not a full persistence standard LCD panel, so there is no traditional motion smearing issue in Pimax 4K VR。
Refresh rate: up to 90Hz in Asynchronous mode, 60Hz in Synchronous mode.
By
PimaxVR Team
Hi there. Please add more options to change screen resolution for playing games. 1440p 60hz, 1440p 90hz asynchronous. People who have top graphics cards want to run best quality possible. Thanks! :wink:
@Davobkk,
Thanks for your suggestion. yes, we’re going to release a optional patch for others who want to enable 1440P in direct or extend mode.
Hi,
Can you give us an estimate time for releasing the patch? This month, next month?
I receive my Pimax tomorrow. Many of us will be happy if you can release it early even if it’s not 100% ready. We will test it for you
Thankyou
Hi, I was wondering which panel is being used in the Pimax ? In the code I see references of “sonic 4k” and also “TSB”, which could mean Toshisba, but also might be unrelated. Thanks
What does this mean? I tried to change tthe refresh rate in the Nvidia settings (customize settings) but for some reason it will not stick. How can this be accomplished? Thank you!
