Ok, let me guess
Continuing the discussion from Piplay v1.2.x lower image quality:
I am currently working on a dual display HMD using InfinitiEye open source. From the facts I learned while testing, I am guessing this is related to 8K.
8K has a different distortion than 4K, so additional rendering is required to be compatible with steam vr. The rendering of star vr is understandable because there is already known information, but pimax is not known and can now be guessed through the v1.2 driver.
If you think so, you will understand all the strange results from the current driver.
ps : I tried to reply to your post, but this post has been created. :smile:
hello,
with the headset u created u can play steamVR ? is just an extended screen ?
Yes and Yes. In addition, since I am using osvr, I can already use positional tracking and controller using kinect and psmove.
do u have how to for using kinect for the headtracking, i realy want try this ?
thanks
There is no article I have summarized. But I will link to the starting point.
And, the Kinect sensor tracks the body. As a result, we can move in virtual space.
However, now that Nolo is released, it will be easier and cheaper to do all this.
u want talk about nolo
but nolo cost 199€ is too expansive
if only psmoveservice stoping using riftcat and focalise they dev to use the third psmove to head…
if only i m a dev
thanks for the link
Of course, the osvr plugin, which uses the third psmove for positional tracking, is just beginning to be developed. It would be good to discuss this in Google Groups.
I don’t think the price of nolo is so expensive. And I think it will succeed in the public.
look the price here —> https://www.nolovr.com/store/
and it’s a pre-order
I know. Think about how much it will cost to apply 360 degree positional tracking using psmove. Also consider the installation process.
I recommend nolo easy to install and easy to use.
But with riftcat that work
Why without is not possible?
ut i think u right.
psmove works but it’ not perfect, i try a Oculus CV1 on a shop, and it’s really other stuff
The osvr plugin mentioned earlier is osvr-psms.
That will help you. I am going to try it.
