Hello,
I have a Windows 10 64-bit Pro and a Nvidia GTX 1080 (disabled internal graphics)
I am having an issue after preforming another re-install to try to get direct mode to work. I uninstalled, Oculus runtime and drivers, SteamVR and Steam, Pimax. I even went to make sure the directories were not left behind. I installed PiSetup_1.1.74_x64(int’l) and have not been able to get the PiDesktop application to start. PiDesktop and PiService show as running inside my taskmanager, as is PiServiceLauncher. When I check my Event Viewer I have tons of the error below being generated every second.
Please Help,
Thank you.
The description for Event ID 0 from source OculusVR cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Error: [From Service] {ERR-026} [Settings] WARNING: Unable to write settings file: ͈ȷ/Oculus/NetServer.cfg
the message resource is present but the message is not found in the string/message table
