It me or there is a problem?? After i download the new piplay 1.1.92 my windows 10 said (file not fund) weird!!
The problem is with the parentheses for (int.). Rename the file to PiSetup_1.1.92 and it will work.
Oh ok thx a lot!! It work now!!
Boy was I lucky to find this fast or what… thanks !
Also: if you created a new folder and copy past the name, you need also to remove the () or it will not work.
broo your a life saver
