Have you however measured your TV in angles (in degrees)? You should try it to realize how reporting FOV and reporting the dimensions differ.
You can see how big FOVs “declare” the two headsets themselves here (HMD Geometry Database | Collected geometry data from some commercially available VR headsets.), then we could resume the discussion here.
Now your just being stupied. Pimax is the only company that specify horizontal so contact Oculus, HTC, HP and so on ask them to specify there FOV horizontal.
Those numbers are not Close to true for me, my Vive was 100, my 5k+ is Close to 150 on normal FOV horizontal.
That Is renderer FoV it’s different from visibile FoV
Hi, but they themselves declare a diagonal FOV 170, and a horizontal 140, well, horizontal write a little more and it very much depends on the face, mask and other factors.
True, but you cannot see what is not rendered.
