Mod idea for Low IPD and Small nose
So I’ve been using my 8KX on and off and it’s honestly the best way to enjoy VR basically once every week or two.
But the more I use it I notice something with the X.
If you have a low IPD of 60 and a small nose like me, you will get Light coming into your eyes when it’s not supposed to.
If you have low IPD and a small nose. The inner edges of the lenses are close enough to the adjacent eyes that light from the lenses will enter the wrong eye.
The solution is to have something blocking the middle part highlighted in RED.
I’m looking for some mod ideas. I’m like 80% sure I’m not the only one that has this issue. It’s very subtle at times but distracting.
I got this issue after doing the extreme ipd mod and just stuck some black tape in between the lenses which did the trick. Sadly that wont quite work here due to the mesh being in the way but you can try and tape it to the top of the nose cone going up. One on each side that sticks together. It doesn’t have to be perfect.
