So @PimaxVR @Matthew.Xu @bacon
Since Pimax is so modular, why not add a module to replace just the thump part of the controller?
Make a Trackpad or Thumbstick module to add, instead or two different controllers (or four, for the left handed)
In SteamVR the Trackpad is used for multiple uses apart from joystick. So make just 2 modules that can be purchased separately, so that you could play in both ways and be compatible with everything.
It would also be good as a replacement.
Be wise.
