I really like using large fov, but can’t when most games require PP cause th resolution becomes really bad…Is this going to be fixed in the new pitool version coming this week…? @PimaxUSA@Sean.Huang
And also, anyone noticed how assetto corsa was rarely changing the resolution and sharpness no matter how much you change pitool and Steamvr SS? i Tried 0.5 and 2.0 Pitool and it looked the same in both for assetto corsa… even tried changing steamvr from 150 to 280 and fps didn’t change at all (stayed at 33 fps all times). I was closing the assetto corsa launcher everytime i changed these settings…anyone else experienced this?
Oh so that’s a good workaround? Does it have any bad side effects…? Cause I thought when you change the FOV, you need to restart steamvr otherwise it’ll give weird artifacts…or is that not true?
