Just Reveived the 5K+, Have Some issues
So I’ve got everything set up. PiTool detects everything, I can start SteamVR and so on. But I have two problems.
  1. Powering on a Vive controller crashes SteamVr Instantly, so I cannot use controllers at all.
  2. I’m getting a “snow” effect when running apps. Little white dots popping up everywhere.
Any known solutions to these problems?
Edit: For those that get here, the solutions were:
Delete openvrpaths.vrpath in AppData/Local/openvr and rerun steam vr room setup
Re-seat the headset end of the cord
With white popping dots check headset plug (mske sure firmly seated) & try a different dp port. If availably try on another pc.
Otherwise you might have a bad cable. Some have found a different wall plug adapter or usb port.
Vive Wands not sure on. Try Steam lvr pairing option.
@park & @spamenigma & @barshiftgames might have some tips on lhes & controllers.
In the Banner check 5k 8k directory @Davebobman has created a goid troubleshooting topic i think might be in Getting started faq
I figured out the controller issue. I had to delete my openvrpaths.vrpath file an rerun room setup. For the cord, I cannot figure out how to re-seat the headset side. It looks like it’s sealed on there and I don’t want to pull too hard.
Edit: Randomly finagling the cord fixed it :stuck_out_tongue: guess I eventually put pressure in the right place.
https://community.openmr.ai/t/how-to-detach-the-plastic-mask-i-want-to-detach-the-cable-noise-problem/13212?u=heliosurge
Awesome glad you got it working.
