Is any use Logitech PowerPlay with Pimax?Here some trouble.With Tracking
I use Logitech PowerPlay & G903 With Pimax 5k+ , Got some Strange thing…
TLTR: If use PowerPlay charge function With pimax and touch Pimax’s surface will cause Tracking issue.
When i touch pimax 's surface with a finger, the track lose immediate…
Tryd use some Glasses Clean Cloth to Mask the Pimax, but still tracking fine…
I confused try replug everything, dosent work.
At last i try disable PowerPlay’s charge function in Logitech Gaming software, everything goes normally…
Then…
Enable charge and touch pimax -> Do Not Track
Disable charge and touch pimax -> fine
Trying move pimax to another usb port doesn’t fix.
Totally unacceptable…
Are you using base stations? If not, that might explain what you’re experiencing. That mat is a big inductor which generates a magnetic field which could interfere with the accelerometers in the Pimax. If you are using base stations, then it might be a cable grounding issue.
i am using base stations,and i found a link…
This issue also appeared on vive…
So the issue is a bug between Steam & logitech Power play mouse.
Yes electrics are funny.
I had the grounding issue / voltage leak that affected my TV by the HDMI cable and one user reported his steering wheel motor killed his Pimax tracking in the same way you’re experiencing, just by touching the headset.
