IPD setup improvement question
Is possible to make that green cross in two different transparent colors?
It would be way easier to set ipd correctly because doesnt matter how far are the crosses from each other, brain will try to merge them. But if the crosses are in different colors and transparent you still would be able to see the difference.
Yeah we suggested that & are waiting to see if the team can implement. Ie blue & yellow would make green.
@Pimax-Support
Awesome! Exactly what i was talking about!
Thanks @Heliosurge
@Redcore It’s difficult to achieve this solution of “blue + yellow = green” at present, product manager will consider to replace the current green cross with a noticeably picture in the future.
