IPD needs to go smaller than 50
I can’t get the IPD to look okay. It hits better the smaller I make it but it stops at 50 and still isn’t quite right. Can you make it go smaller? It makes me dizzy and sick the way it is now.
Has anyone tried using an injector like Vorpx to get more precise control over things like IPD and lens distortion parameters?
Have the same problem. Setting IPD in Piplay to 65, which is more or less my measured distance, makes image not recognisable. Setting it to 50 gives the best image, but its not perfect. Offcourse its a bug, so please fix it, but at least for now let us set it lower then 50.
Thank you for ur suggestion. I will hand in your suggestion to our engineer.
