Introduction of the LiveViewRift
This is the introduction of the LiveViewRift, its biggest advantage is to localize and track very smoothly, little drag. In such a powerful effect, its simple and rough interface does not look so ugly.
T1:Program Constraint:
1. please run under the extended mode.
2. the current support for video format is not very good. This will show the provisional measures compatible at last
3. Minority procedures, all kinds of abnormal situation please explore by yourself.
T2:Image & Text Course:
**S1:**Double click setup, just next, without any branch options.
**S2:**Play video:
After double click to open the program, we can see the settings interface:
Do not panic, it is very simple, directly set according to the following settings:
Then you can start to play, is not very simple?
**S3:**Shortcut key operation:
We can see there is a bunch of shortcuts operation on the top of the play interface, how to use it?
It is the most essential place here, the surface of the operating window can be directly operated by the mouse!
For only one button switch operation, click on the line;
Video progress directly to drag the mouse or click on the line;
