Installed 1.2.85, Piplay keep seraching device!
installed 1.2.85, Piplay keep seraching device! Actually only 1.1.92 works for me, but I’m ordered NOLO
that’s why I need to update the driver.
Hi
I may be telling my gran how to suckling eggs here, but did you turn off your antivirus program first.
I had the same problem when I changed from 1.2.75 to 1.1.92
I didn’t turn it off when I installed 1.2.75 and everything worked fine. When I installed 1.1.92 it was constantly searching for the headset. I turned off the antivirus re installed 1.1.92 and it worked fine.
Hope it helps
May be,that’s not the case, mind is working fine until whenever trying to either install a version that has higher display (2k) as default or setting 1.1.92 to 2k then mind is keep on searching device (that is my assumption lately). Thank anyway spoony.
