Illegal device? Excuse me?
I just updated pitool and it says that my device is illegal…Imgur: The magic of the Internet
This headset was purchased directly from pimax official website!
Strange, have restartet the computer.
Yes, I did reboot my device and pc afterwards.
then go back to 261 or 25x until the problem is found.
@Heliosurge any idea?
Never saw that message. File a support ticket as it mentions in Pitool. @PimaxQuorra @Alex.liu
Thanks @dstar for the poke.
please send your SN to the doman to check your device
Thank you for quick reply.
I sent SN to @Doman.Chen
I rolled back to old version and it works as intended now. It seems as if the newest update is what caused this issue.
I have same issue. I have pm’d SN to @Doman.Chen
I have same issue with my artisans. Old firmware version works fine
