I have some games on my oculus account when I had a rift s like boneworks and wondering if I had to configure them for the 8kx like how PImax Experience auto configs steamvr games.
If You’re launching them through Pimax Experience they’ll have profiles, yes (they’re not automatically configured yet - they’re just based off a common profile and You can adjust to Your liking).
If You’re launching from PiTool I’m pretty sure (haven’t used it for a long time) that You’ll have to manually load the profile before starting a game from the “Games” tab.
If launching from PE You can choose to use ReVive (through Steam) or the Oculus built-in feature of PiTool (Oculus or ReVive tab/collection in PE).
You have to install ReVive manually.
You know I always assumed starting the game from the games tab automatically applied the configuration for that game.( Because, you know…logic)
Might work in later versions but didn’t back when I tried it out so I just got into the habit of applying before starting which seemed kinda silly…
Really liking PE though…
It would be so odd if this whole time I’ve thought I was applying profiles, I actually wasn’t. I’m not gonna go check. I’m afraid of the answer.
