Did you try to put your hand like you will catch water, and touch with your fingers the upper part of the speaker while you bring your hand to your ear? The sound bounces and it’s another world. 200% more sound and depth.
I will try to create a 3D printed piece to achieve this same effect modding the SMAS.
