Hey guys! As I already replied in another thread about a “wizard”, let me just repeat myself a little in here too clarify a few things:
Yes a wizard (like mentioned above) could definitely help some people, even if it theoretically is a step backwards and also of conflicts with the entire profile-based settings PE is made for, I think some people might need a 1-2-3 step wizard to just get started. Me and Armin will work on a qizard like this.
But…
One thing to remember though, is that no matter how much you customize/change PE or no matter how cool wizard we create, a VR HMD will never be plug and play out of the box. This is not an IPhone. SteamVR is definitely not plug and play. At least not when you want to bring the best our of your HMD, whenever its Pimax or Valve Index.
Not even the Oculus Quest is plug and play when it comes to optimized settings, despite the fact it only contains a library of a few hundred games all optimized for the device. Yes it can run games with 1 click with default values, but once you want to adjust anything ,you need to fiddle around.
Using a Windows based PC, which can have 1000 variations of GPU/CPU/etc, its basically impossible to get it really optimized for all scenarios and for every single person. Or maybe it is, but would require a huge team of people working on this.
Same for IPD guide. Once we add it to PE, the guide will be a great “wizard” to (kind of) help you finding the correct IPD+offset etc. But it will never be a one-click solution to please everyone. And it will either way require you, as a user, to determinate if the IPD is your correct value. So its basically a manual process of calibrating your headset for your eyes, which some charts and images can help you with. Nothing and nobody else can determinate if the IPD is correct for you or not - its all about what you see, and in the end, nobody can see what you see.
As a Pimax user - or actually a VR user overall - there is and always will be a level of knowledge/skills required. Same for Valve Index or G2. Its basicaly the same for PC monitor gaming. Im talking about kids playing CounterStrike for instance. You can install windows, install drivers and just start the game as-is, or you can spend weeks tweaking the settings until you get satisfied, and eventually - most likely - get a better performance and image quality. After all, its not an XBOX console. It requires some fiddeling before you hopefully get satisfied. This may or may not be the reason why millions people just buy an XBOX and stay away from PCs.
While PE actually doesnt really require much skills/knowledge to master and undestand, it still may require some time from you to get adopted to the UI and understand the basics:
- What is a settings profile
- What is SteamVR optimization
- What does it mean to “apply settings upon game launch”
This is basic stuff that you simply should learn and adopt to, sooner or later. Im sorry to say this, but there are no straight forward highways to success. There are shortcuts that might help you, but in the end, you need to hold the steering wheel, find the way and at least know which one the gas pedal is.
I hope you somehow get my point… I dont want to be harsh here, but I feel that nowadays, we are in times where people just doesnt want to adopt to anything. Things are just supposed to work. Magically by themselves. Everything else is garbage. Im sure others agree with me…
