I have this for a long time now,i cant get oculus games to work.
I am on the latest pitool.
Does somebody has this too?
I realy want to try lone echo 2 with the rtx4090 on the pimax 8kx…
Lone echo 2 runs also awsome on my end do you use open xr ?
Did you try different Fov settings ?
The oculus games doesnt start somehow…
did you try starting up oculus software manually before using the pimax expirience ?
hmm hard to tell from here, doesnit create logs ?
yes i do that… its very strange…
