good morning. I have a problem. when the 5k plus viewer and attached to the HTC live station I can’t touch the viewer. It disconnects me. loses tracking. how can i solve? thank you
If you use 1 Lighthouse, keep it at least 2-3m away from you. Keep it at your front.
You need a minimum of 2 Lighthouses to get 360° tracking.
Also, try PiTool version 180!
is about 2.5 meters away. pimax use only for sim. but I do not solve anything
https://community.openmr.ai/t/new-pitool-1-0-1-180-is-available-now-from-pimax/21281
Try this. It detects the station much better and more reliably than 132 or 144.
So if you touch your Pimax headset, you lose tracking?
It might be a problem with static/residual electricity, or whatever it should be called.
I guess youre using some steering wheel?
@blitze was it you having a loss of tracking with a steering wheel set?
I lose the tracking when I activate the dynamic station. Is this because my pimax cable is not shielded?
Try to run a cable (wire) between Your computer case and the “dynamic station”. It’s worked for others before.
EDIT: I thought by “dynamic station” You meant a motion rig or something like that but it seems to me You mean basestation or lighthouse? If You don’t have anything like a motion rig, wheel or other peripheral connected (via USB) I don’t know what to do besides opening a ticket with support. Your unit might be faulty.
Not sure whats the problem here.
I have already placed the viewer on the ground with a PC and a dynamic workstation done
