Thanks for the quick reply. I’ve only just installed 1.2.57. Using 1.1.92 I always got the game being projected onto a screen in a steam room as the earlier posts mentioned. I am patching the game with ReVive. So, depending on which PiPlay version I use, this is what I’m seeing:
1.1.92: projected onto a flat screen in a steam vr room
1.2.57: can’t see the game at all, just the wireframe dome and a steam menu.
I must be missing something fairly obvious but I can’t think what it is.
I’ll edit the steam config file too, but I think that’s more to do with the screen pausing. I’ll try it though.
Very grateful for any more ideas, thanks
[Edit: I’m back on 1.1.92 now, and I’m still getting the wireframe dome screen. Help ]
Sounds like you need to disable Steam’s desktop theater or whatever it is called. Right click Dirt Rally in steam, go to properties, there should be an option to disable theater mode. If not then try the main Steam settings.
Think it’s locked at the monitors maximum resolution, which for me is 1080. Does anyone know if its possible (with some clever fiddling) to get it to run at 2k on the HMD and even better, prevent it from running on the monitor altogether (to improve performance)?
You’re right actually, when I look at the cockpit etc, I’m certain it’s in 2k. The trees in the distance look a bit blurry (for me) which was why I was thinking it was at the lower resolution but if I look at the detail around me it’s actually very good.
I’d be very interested in whether anyone has managed to stop it from rendering the game on the monitor though, via some sort of hack. My frame rate does get a bit choppy at times and I imagine having to render it on the HMD and the monitor isn’t helping performance.
Got it looking pretty awesome now. I’d forgotten to up the resolution in game, and got my IPD sorted. I’ve also cranked up the VR settngs to ‘Nausea Level’ in the HUD setting. Dusted off my old LogiTech Momo.
Have to say: what a superb gaming experience! Thanks for all the help with this
I just don’t want to go back to earlier the Piplay version.
I’m finding that the video quality of the latest Piplay (1.2.57) is very good and compatibility with SteamVR and OCHome is better as well.
Hopefully I’ll find a workaround for HL series as well. But I’m glad that it’s working for you.
