im honestly just curious.
Best guess is $599 for the headset / $799 for the full kit, Headset, Controllers + Lighthouses
You will know for sure on Tuesday
If you order the full kit they will send you the headset first in December and the light houses later in Feburary
You can also use the Vive light houses. If you dont already have them HTC sells them separately. The headset will work fine with 1 Light house for seated gaming
