How can I use the direct mode?
I bought Pimax last week.
My PC is windows 10. GTX1080, 16G RAM, I7 CPU
But I don’t know how I can switch to direct mode? It just has Pimax mode inside. Is that the same?
Yes, the Pimax mode and the direct mode is the same, at least with a Nvidia 10 Series :wink:
Dear Jason:
Just use the Pimax mode.
The application for Ocullus does not have compatibility in direct mode.
My graphics card is GTX 1060.
When installing the Ocullus driver, the Ocullus application is executed.
However, the application for the extand mode can not be executed.
There seems to be a conflict between the driver for Pimax and the driver for Ouclus.
Is there any way to use them together?
Or is there a way to use the extand mode application on Ocullus?
