I have applied for the Mid Autunmn 8KX event and also received a confirmation message. unfortunately i do not receive any further confirmation.
I cannot send my text, please help me
I have added you to the 8kx event group. You should know be able to post in the #PIMAX-HMD:Reviews-8KX category
Thank you very much, thats very kind of you. might it be possible to add me into the story category?
You can post there. If your entry is 8kxstory create your topic and add the 8kxstory tag.
Just click on the # link above in previous post
Hi INVR,
Have your problem been solved?
Regards,
Apple
