I have this headset since Feb. as an backer, had no problems so far, till this morning.
Last saturday was the last time I used this headset with no problems, shut down windows and cutt off all the standby power. This morning I turned on the standby power, and no blue light from the Headset, nothing even after windows has started.
I measured the voltage from the adapter and it still reads around 12v.
Is there something I can try to get some life into the HMD?
I already created a support ticket, but maybe there are some people here with some clever solutions
Thanks for your response, but the HMD doesn’t give a sing of life. Not even a quick LED flash.
In the morning I had a really quick response from pimax, and we had a little chat. We suggested another wall adapter, which didn’t solve my problem. I will wait till they are awake in China to see what’s gonna be the next step.
SOLVED
After some conversation with support, the only way to fix it was a replacement headset which arrived yesterday.
I must say that the support from Pimax was good in this proces.
Keep in mind the small language barrier ( from both sides ) and some delay in replies due to the timezone difference between Europe and China.
Thanks to the Pimax team who helped me! I’m back on track!
