Last time I test psvr and I found that it has light at the left and right edge sometimes
Today I just try it again and try to close one eye to look at the middle, I see that the screen separator at the middle has some space, so I can see image from other side.
sample : screen seperator at the middle
When I can see the image from other side, it will become floated image at the left and right which continue to the overlap section.
But if no space between the screen separator and front frame (or mobile in cardboard headset), I will can see screen seperator easily and it will become black curve at the left and right edge instead.
I have ever test mojing s1, if screen is close to the lens, I can’t see the screen separator, but the image is blur, so I have to move screen out and so I will see it again.
Who know how to solve this issue.
I am concern that this effect will be happened when I use with 8k because it has big fov and the screen seperator or image from other side will float at left at right continue to the overlap section.
